The best way to remove window tints ?
Hi guys,
So I wanna take the tints outta my 6n buy don't wanna be left with all the glue over the window when striped.
Who has done this and how ?
Thanks in advance Gareth
  • Replies 16
  • Views 1.4k
Glue and tar remover, Stanley blade and a lot of spare time.
Thats about it.
You dont want the glue and tar remover to drip on any plastic as it will strip the colour out.
Ok there are so many people saying diffirent things lol cheers
forgot to say, find a corner and peel off as much as possible first, then use the G&T remover to get the glue/bits that didnt peel off.
Hi guys,
Where abouts are you based? i have a set of front 6n windows, £20 for pair to a fellow polo owner. I'm in rotherham, cheers jud
a big hammer will do the trick nicely.
lol joking t cut is good
Hi guys,
I've got 2 fronts mate it's the back that are the problem
Although my passenger window is scratched and could do with a new one lol
depends on the material really and the glue, have you tried to get it off already? easiest thing is to buy some glue remover it will make a long job a ten minute job.
I have some i can send you a small tube of it if need be
Nope i haven't tried taking any off yet, and where would
I buy glue remover from lol ? So what your saying is rip
The tints out then use the glue remover ?
On my mates golf we went at it with a heat gun to try and "loosen up" the glue and peeled film off. Depending on how patient you are/how long the tints been on as to how much residue is left behind. We then used a shit load of fast glass and liquid buffer spray to remove the remaining residue, which was a labour of love!
I'd be interested to use some proper glue remover, see how it fairs.
i can not see the tints leaving a glue residue, but just pick at a corner and give it a trial run
glue remover can be bought online at various places, ebay is best bet
glue residue from tints and i have found from vinyl is a nightmare to remove. As you said above it takes alot of elbow grease. Unless you get some glue remover, it softens it and turns it to a sticky paste you can just scrape off. We use it on a daily basis and it is a god send!
Dk how much wonga would you want for some ?
i had rear tints on my mk2 polo and all i did was peeled a corner back and got a heat gun on the film as i peeled it. Came off with no probs and were on the car for 6years.
What there was no glue left on the window after you peeled it back ?
its a self adhesive film like sellotape, its not gonna leave much residue.
yeah it just peeled off. No marks or sticky patches. If you just peel it some of the sticky stays on the window but the heat gun stops it sticking to the window. BUT DONT GRAB THE FILM WHERE YOUVE HAD THE HEAT GUN THOUGH, IT GETS VERY HOT! Found that out the hard way :(
^^comment above. it sounds like sellotape when you peel it off ^^
Edited by dicko
