Sourcing marine blue in a tin for guns
As the title says, marine blue in a tin compatable for a gun, needs to be a good colour match so no rubbish company's please! Many thanks
Cars a mk2 1990 cheers
  • Replies 9
Rainbow in ferndown is the best place for colour matches around here mate. They'll probably do it in solid colour as well so you don't have to lacquer it aswell!
Any decent body shop that supplies to the trade will mix you up a batch. Go for 2K. Its pricey, but even a mug can get a reasonable finish
Didnt think they done 2k anymore.
Thought places now selling 2k and cellulose paints are end of line from when the law was introduced back in 2009.
I know you can still get celly and 2k primer and clear, but thought basecoats now were only produced in a water based?
But dont VW do paint?
Edited by Monkey-man
Nope, we still use 2k for everything, but as I say, don't bother with base and clear, go for straight colour and you'll get a better finish if you're not 100% confident with a gun!
Am assuming you work in a body shop by the way you said we?
If so then you may be the man for my question.
I know celly isnt compatible with 2k eg a celly primer with a 2k base and vice versa. But If i was to use a celly primer with a water based base coat and the a 2k clear, would that be ok, the paint wouldnt react with one another?
Ah right, well in the long run I want laquer but obvs my car doesn't have it at the mo so shan't bother.. Anyone got a number for place in ferndown? Will try get some tomorrow cheers
I got cellulose from halfrauds at trade price, does this mean laquers needed as well?
If i remember correctly no lacquer is needed matey
2K is much easier to use. Celly based paint is harder to work with, and requires more finishing (flatting etc.). 2K can be an 'out of the gun' finish. Plus, I'm not sure I'd trust halfrauds for a decent colour match. Stop being a cheap skate and pay up. You will not regret it
