Rustproofing Fuel Tank
What the best way to rustproof a fuel tank. Am guessing spraying it with something. But what shall I spray it will, just paint or is there something that will do a better job?
  • Views 1.5k
epoxy mastic or epoxy primer is about as tough as it gets , its used on boats , then some stonechip on top
then wash around the filler often to keep the mud n salt out
did a couple of coats of por15 paint on the last one i did, then some stonechip over the top
Get it powdercoated...it doesn't get more rustproof than that
There was some stuff you poured into the tank and you could paint it on the inside as well to protect it.
Outside I used "rubber"/rubberising paint. stuff is expensive but does the job well.
this will be better than powercoat. Problem with powder coat is that when it gets chipped it is very good at holding water in. so is por15 to an extent but with stone chip over the top it is about as good as you'll get.
those pour-in repair kits are more for sealing a tank that's gone porous or is rusty and a replacement can't be found. I'd not bother with it on an otherwise good tank.
