Thinking to do a mk3
Well as i'm breaking my polo i'm gonna need a new car soon.
Was gonna go jap, but before I do can some people tell me what Mk3's are like, they seem to be the car to have.
Tell me a few pro's and con's about them.
What they like on insurance (1.0)
Fuel?
Any common problem?
where is most the rust gonna be?
are parts easily source able?
Cheers guys ;)
Edited by youngdub
  • Replies 19
  • Views 1.4k
Cant really answer the first one too many variables.
Fuel, my 1.3 on SPI wasnt too bad, id assume the 1l gives a bit better MPG on mixed driving.
Engines are pretty bomb proof, common problems are small oil leaks from head gasket above alternator (tends to reduce its life) and rocker cover, blocked breathers, Hall effect sender in the dizzy, resistor on the heater fan (still works on setting 3 regardless), blue temp sender causing poor MPG.
Rust is normally under the battery, door drain channels and if its a GT/G40 under the plastic trims. Petrol tanks filler necks tend to rust and leak.
Parts, second hand there plentiful, new are getting harder for certain things, most basic parts are gsf, ecp, ebay or local motorfactors.
Sure theres a few more things I've not thought of.
Front jacking points like to rust too. 1 liters ain't great on fuel because they have to labour more to get anywhere
Nice one guys, any more peeps?
Mclovin: should have thought about that one after i got them welded for the MOT when the sill split during jacking. :lol:
As said the arches tend to rust as muck collects under the arch lip and then acts like a sponge retaining water there which slowly rots the arches away at the lip. They need to be kept clean people. They are also prone to rust under the battery, bottom of the doors, around the wiper arm holes, around the window seals and other spots mentioned by others.
Suspension components on non modified ones are often very tired and so when test driving standard ones they can feel very sketchy indeed. Engine range is pretty bombproof and easy to work on. Spare parts are fairly easy to get hold of and there is a good level of knowledge for these cars on this forum so fixing/diagnosing things is easy.
They are simple and rewarding cars to own and you get a lot of fun for your money.
Edited by demolover
All this makes me want to get one. Would you guys recommend it as a first car? Seriously considering to get one and slam it on my RS's
No reason it wouldn't make a good first car, they may not have a lot (read any) mod cons, but they are good little cars and it takes very little to get one looking tidy
Awesome first car. Cheap to buy, cheap to mod, cheap to run and cheap to maintain. Lots of fun and a solid little motor for their age.
What size RS? Dependant on size/offset/tyres/amount you lower you might/will need arch work on a coupe and a breadvan would be pretty much a no go.
As said no mod cons but what they lack in mod cons they make up for in character. One of those cars that you like for no real reason.... you just do.
I have one for a first car now its great I've got a 1.3 coupe and agree.no mod cons and i cudnt care less, I enjoy driving it
Deffo get a 1.3 with a 5speed mk3 as your first car, I've had a 1.0 and it was slow and the 4speed gearbox gets on your nerves after a few months. good cars though!
I've got some 16x7.5 and 16x8.5 no idea of the ET, but I will defo need arch work. But I do body work myself so it's no biggy!
Looks like I'm gonna get a mk3 then, I dunno if I could do a 1.3 as it might affect insurance a little too much? Will still consider the 1.3's tho!
Thanks for all the advise people!
Vish
Cant really go jap as a young driver, unless you're a nonce in a corsa. Jap needs to be RWD and contain a turbo and be able to do that magical thing called drift. Mates just got a s13, sideways round roundabouts ftw. He's an idiot though.
Anyway, i've got a 1.3 spi for my first road legal car, insurance wasn't THAT hefty. Mate has a 1.0 breadvan and you really can tell the difference in the two and like said his is terrible on fuel whereas mine is alright to be honest. Defiantly get one! Want to get a 205 at some point though, had one of them before and i LOVED that car. Only french car i really like tbf
The brakes are terrible! Well, they're good until you get in a modern car straight after driving one and gently touch the brake pedal and realise you've come to a tyre screaming stop because the brakes are so much better! oops
Do it! The coupe is my first car after driving my mums 1.2 clio for a few weeks and I fell in love instantly, I hate it sometimes but overall I love it, couldn't of asked for a better first car. Mines a bitch on insurance though, but worth it.
So you guy would say the 1.3 is a better car to get? I just don't wanna get shagged on insurance, living in London don't help either.
Also, who does good Coilovers for them? PhilJ I'm guessing? Dont want to get a lowering kit. Would rather have Coilovers!
1.3 5 speed is better if you can afford to insure one. Run some quotes up on a 1 litre and a 1.3 and compare them. Only way to find out.
Coilovers and alloys will make more difference than there will be between a 1 and a 1.3 liter, if you can afford to insure mods then you can afford to insure a 1.3
My mates younger brown has just passed his test and can't get a quote under 3k for his mk3, although that has only been on comparison sites so far
My insurance is with admiral on my 1.3 coupe I have two names drivers on my insurance and the insurance is full comp with the car parked on the road with £500 excess all for £1800 it was near £3000 if I had parked the car in my garage and not fill comp either so defiantly go thought the different options and mix them about because there is stuff that will surprise you and ill also mention that if you.plan to pay monthly it might be a better choice to get a loan though the bank pay your insurance in whole and then pay the money off for the loan as the bank usually has a lower apr than the insurance company as my insurance company wanted an extra £700 to pay monthly were as my bank only want an extra £200 on top of the £1800, so like I said its worth trying different options. Hope all that helps. :)
