side exit?
anybody done it or know how hard it will be to do?
also thinking of removing the cat.. will i need a decat pipe? or would it be possible to just weld in another length of exhaust?
cheers
  • Replies 17
  • Views 1.5k
No reason you couldn't weld in another bit of pipe to replace the cat and side exits are easy on mk3 polo's so long as you want it to exit on the passenger side. The exhaust already points in that direction before bending back out towards the back so cut it off before the bend and weld on some more pipe so it reaches out to the sill
i did a side exit on my mk2 bready and was a pile o piss :) I had a 4-2 mani, 2-1 downpipe so i cut the 2-1 and took one pipe tothe drivers side (bit awkward) and one to the passenger (easy)
wish i could find my memory card with my pics on to show you :(
Cheers lads! :D
where i work has a fabrication section so i'll just ask one of the lads to kindly do it for me :p
would any of you recommend removing the centre silencer also? or would it be rediculously loud?
Thanks a lot :)
Its hardly any louder without the backbox to be honest.
I'd keep the center box tbh, a straight through pipe on an n/a engine would be very loud
Depends if your running a catalyst or not, I would defiantly run a centrebox either way.
Well if your running a cat then its not a straight through pipe is it maximus :lol:
heres my attempt
329337_302740153075373_126136340735756_1
Edited by willsalter1000
Didn't know it had to be straight through?
i had motorbike silencers on mine cause i had them comin out just in front of the front wheels and not alot of room
The G missing a backbox is ridiculously loud, I'm tone deaf by the time I get to work. Can't wait the new one to arrive so I can finally shut up that racket!
It don't, i think we're getting our wires crossed. I said that a straight through would be very loud and you said that it depends of he runs a catalyst
Saf a side exit is quiter (inside the car at least) than no back box, its probably due to the sound being chucked out the side of the car behind the driver rather than underneath and resonating around the inside of the cabin
Oh yeah, i see now :lol:
done the side exit exhaust just having a bit of a problem finding somewhere to bracket it up :/
running it without atleast the backbox will burn the pistons to fuck within a few thousand miles the engine needs backpressure
Boom headshot!
