6N2 Starting Problem
went to start my 6n2 the other night and it wouldnt start (didnt even attempt) .. so i presumed that the battery had died and bump started it.
when i got home i turned the car off and yet again, when i turned the key, nothing happened.
i then tried it again the next morning and got the same result, however, later on in the day when i was going to bump it to move it to my unit, it just started like normal ... :s
anybody have any ideas on what it could be? maybe a loose starter motor connection?
  • Views 780
its not when the car is hot is it?
no mate, was when it was cold but started fine now ever since... just dont fancy it happening again :/
any ideas? been fine since.. just dont want it to happen again :/
worth checking your batteries properly connected and starter motor isnt shagged?
battery is fine and starter motor seems ok, someone suggested that the ignition barrel may be worn?
