AIR COMPRESSOR?
Where is the best place to get an air compressor because want to spray my car and all i want is a good compressor for a reasonable price. Ideally a 25lt or 50lt??
  • Views 1.3k
Your going to need a bigger compressor than that matey, far bigger.
Even HVLP guns use around 8.0 -10.0 CFM at between 60 - 80psi. This means your going to roughly go through 180 - 220 l/min. A 24/50 litre tank will empty in a matter of seconds!
Which means your compressor will be working constantly, which is really not going to do it any good! And besides on a single phase compressor motor and pump you wouldnt deliver enough free airflow on an empty tank to run a spray gun anyways.
Best bet if you want to spray your car yourself is at the minimum get yourself a 100 litre compressor. You will want at least a 3hp motor on it, which for a single phase power supply is going to be the maximum your going to get. With this id recommend using a HVLP mini spray gun (touch up gun) and spraying the car in segments (panel by panel). The reason I say use a touch up gun is because you can still get a good enough dicharge and paint spread to paint a car panel by panel. But the main thing being is the touch up guns have a lot lower air consumption and air requirments to operate so will compliment being used with a smaller compressor.
Also another note, if your going to get a compressor, dont get a direct drive, get a belt driven compressor. There far more reliable.
Edited by Monkey-man
hire one!
as monkey says really. a touch up gun will use about 5.5cfm. i run mine off of a 25L direct drive compressor (it was free, so cant complain) and has an output of 7.4cfm. runs the hvlp mini spray gun fine. I use mine to paint wheels and the odd panel, nothing larger.
thanks.
Do not paint a car panel by panel with a mini gun, for fucks sake.
Only option he's got realistically with such a small compressor! He'd end up with a much worse job if he painted it with a normal gun and tried painting the entire car!
