16v 6n fog lights
As title says please
What year is your polo buddy?
If after 97' then it's much easier, basically need a switch with dual fog options, a wiring loom for the front of the car to plug into the headlight loom and obviously the fogs :) haha
If before 97 then it requires running a wire down to the fusebox from pin 13 of the large connector on the back of the headlight switch and also installing an addition relay.
I've got the switch and got the loom but were does it wire into. Its a after 97 btw
Inside the engine bay, look down to the right of the radiator from where you're standing and you'l see the headlight harness/loom plugged into the plastic infront of the radiator..unscrew this and then un-clip the the other half of the connector from the mounting...
Follow this guide http://www.clubpolo.co.uk/forum/index.php?...166235&st=0 from about halfway down ther page (read harris.racing's posts)....ignore everything to do with the fusebox though.
Remember that when you connect the switch, it turns so when you put it in the other end of the clip (the clip that you removed from the mounting) make sure that you compensate for this!
If you need me to go into greater detail let me know!
Cheers mate that should be fine :)
Did you manage to fit them ok ??
