mk2 polo electric windows
Epic revival, how did you feed the wires through from the door to the car? I dont want no wires hanging out it neefs to look OEM! I have some 6n switches i may try and use
Drill a hole in the door and pillar and then use a rubber boot..
  • Replies 28
  • Views 4.4k
Yeahh?? Cool dudee, if i feed it through the pillar where would it end up? In the arch or behind the carpets in the interior?
Gonna order my kit now i thinks!!
If you do it right it will end up in the area behind the interior carpets... but there is only a small access area there. SO take the carpet up first and then drill your hole. You will find the wires for the door light switch there also :)
Nice one thanks mark! Ill report back when they arrive!
