ATV gearbox
Need an ATV box as the one I just brought from a member here has a crack in the casing, so this one is going to go with my own damaged box to make a spare.
So I'm looking for a good condition, no hidden secrets ATV box to use as my primary gearbox.
Id like it within a decent radius of heathrow, or atleast down south, alternativly if you are willing to courier that's fine.
  • Replies 8
  • Views 709
Don't qoute me on this but I believe you could get a standard mk3 gearbox remove the gears use that casing & transfer your atv gears into that gearbox casing
Between my original gearbox with its fucked internals, and the new one with a cracked case, I am going to build one good one, but this will be used as a spare. I need one as my 'main' box.
bump
Ttt
they're like rocking horse poo mate.I'm using a 8p gearbox on mine .stronger box aswel
they not stronger... they same strenght in general tbh - all mk3 boxes
ah right thats just what iv been told.i stand corrected
Edited by poloandyb
have you got one sorted yet mate? if not i have one that was recently refurbed, I've not ran it but the previous owner did in his mk1 after rebuild and said all was sweet
