smoothed bay?
now that the polo is off the road until after winter i am aiming to get some more major bits done
so seeing as the engine is going to be out again so i can have the bottom end lightened and balanced, i am wondering if i should have the engine bay smoothed out...
i really like the look of it when it is done properly, but where the f**k does everything go?!?!?!
and also with the afh being such a tight fit ime not sure i could even get it back in without causing some major scratches!
also some pics of polos with smooth bays could be good ;)
  • Views 927
are you going to the GTI Festival tomorrow? il have mine there for you to look at.
there should be photos in my thread also in the mk3 build thread section
i was going to, but other things have come up now :(
i will check out the thread though!
Check mine too Bilco. Mine still has the firewall/scuttle (unlike Kiz's) so I have stashed most of it behind that. I didnt have a header tank as i have an early top fill rad. I have a slimline fan, and I've put the early (small) washer bottle inside the scuttle. The coil has been relocated to be in front of the fuse box. Also my facet pump has been relocated to be next to the battery. Wiring has been wrapped and passed through the wings, with the lighting looms popping back into the bay where the 'chassis legs' meet the front slam panel. I have also gotten hold of a 1.4 thermo housing which has far less pipes coming from it. Most of these would have had to have been blanked as I'm not running the original fuelling system. The single fuel linw will run from behind the scuttle to the carbs, and i have re-reouted those through the wings too.
Again, check the build thread for pictures, but eventuall all that should be visible is the engine, rad (with the custom cowling), clutch and choke cables and the single fuel line. I'm still working out how to make the king lead reach though, looking like a custom job on that one
check my build thread mate i have removed firewall and smoothed the bay
