VW Polo Gti
Hi guys, have decided to put my polo up for sale.
Have owned the car for just over 18 months now, but due to qualifing as a sparks, I'm in need of a van.
Car information
Y plate VW Polo Gti in black.
Mileage: 113,000
MOT until: 1st June 2012
Tax: April 2012
Usual spec. Electric windows. Electric mirrors, Xenon headlamps, headlamp washers, Climate control, RCL, Airbag, PAS.
Service History
First registered 01-06-2001
30-9-2001 - 10,062 Oil change, VW main dealer Reading.
31-5-2002 - 19,535. Oil change. VW main dealer Reading.
2-6-2003 - 30,079. Oil change. VW main dealer Reading.
12-6-2004 - 39,364. Oil change with Longlife engine oil, Longlife inspection, spark plugs changed, air filter changed. VW main dealer Reading.
26-7-2005 - 45,398. Oil change. RA Engineering Reading.
22-10-2007 - 69,896 Oil change, spark plugs changed, fuel filter changed, cambelt changed, air filter changed, brake fluid changed. VW main dealer Reading.
8-1-2008 - 71,202 Oil change, spark plugs changed, air filter insert changed, brake fluid changed. Abbey Service Centre, Northampton.
18-7-2008 - 87,372 Oil change, spark plugs changed, fuel filter changed, air filter insert changed, brake fluid changed. Abbey Service Centre, Northampton.
17-3-2010 - 99,169 Oil change, fuel filter change.Volkscraft Exeter (VAG Specialist)
14-5-2001 - 108,000 serviced by myself, oil change, new spark plugs, fuel filter change.
Receipts
Full genuine standard exhaust system fitted 19-6-2009 costing over £500!
All important Recon gearbox fitted 28-4-2007 costing £459.99
New alternator fitted November 2010
Rear lamda sensor fitted March 2011.
Lots of VW and TPS receipts for various parts. I have always used genuine parts since owning the car, even down to the screenwash!!
Modifications
Before owning i bought the car standard apart from a BMC forced induction air filter.
Since owning:
Exterior
Resprayed front and rear bumpers, bonnet and front wings
Resprayed rear spoiler and rear badge split and inside sprayed
Arches flushed/rolled
Colour coded Gti splitter
Stubby drivers side mirror
New Rear VW badge
New Front MK6 Golf Gti badge
Legal pressed plates
Upgraded Xenons
New Front Indicators
Interior
Polo gti 9n3 handbrake cover
Lupo gti gear knob (original had faded)
Audi TT pedals
Alpine "ipod-ready" head unit
Momo 280mm steering wheel
Vibe 12" active subwoofer
Alpine 13cm front speakers
New interior door handles
Tweeter covers resprayed gloss black
Wheels/suspension
Ronal LS' 7.5J all round 185/45 tyres fitted April 2011, 1 tyre is only just legal (wheel bearing went + tracking is slightly off)
or
Standard BBS RX2's resprayed anthracite grey, lips polished up
15mm rear hubcentric spacers, 5mm spacers on the front
2 yokohama s-drives 195/45/15's fitted in september 2010
JOM coilovers fitted may 2009
Engine
Audi R8 fuel cap
BMC air filter.
Brand new front discs and pads (less than 50 miles on them)
New discs and pads on the rears fitted april 2011
Callipers resprayed
New CV joints
New wheel bearing
Car is cleaned every week, and was detailed by myself in august. Cleaned, clayed, cleaned, polished, glazed, waxed!
Always cleaned with good quality products.
Bad points (every car has them)
Couple little parking dents, the car is 10 years old.
Only have 1 key. Other key was meant to be "sent in the post" but never showed up.
ABS fault. Was not told about this when i bought the car, was discovered by my mechanic, a relay has been put onto the car so the light comes on and goes off with the other lights when you turn on the ignition. :angry:
Have not tried to fix this so could be just a sensor, but thats just wishful guessing.
Drives as it should, changes gear with ease, light steering, starts first time everytime. Since owned the car, this now is the best condition its been in, had a lot of money spend on it, all doing it properly.
Pictures
When first purchased
And now
or on the standard wheels
Price(s)
I'm going to try and be a bit flexible so you have options!
Car with out wheels (bring your own) £2300
Car on the bbs standards £ 2500
Car on the Ronals £ 2700
Also have a full set of mk4 recaro's which i was planning on fitting. And all the material needed to retrim the headlinging/pillars.
Add £300 to any above price if you want to take these aswell.
P/X Only small vans considered, with cash either way.
Chris.
  • Views 361
SOLD.
