polo saloon
Hello, i am going to look at a polo saloon (6k?) tomorrow morning,
It is a 1.6L 1996. possibly the 75vhp model?
i have searched for threads but can only find people topicing about picking them up, none about going to view one.
So just general information about common problems, what to look for when viewing etc?
All comments would be a great help, cheers.
(Car is on 50k miles, cambelt was done at 35k)
  • Replies 28
  • Views 3.2k
Anyone? :(
Most likely the same things as the 6n, so mainly rust :lol:
Tbh just do the same as seeing any car.
same things, just bare in mind body parts are harder to source already painted, as not many around.
6n bits will not fit no matter how much people tell you they will.
d.
pedal box is good to look for they brake at the top and are a pain to fix listen for gearbox whine or being hard to get in gear rust on the sills and arches and overly bad oil leaks
Thanks for the information both!
Read some reviews online, and overall seem decent enough!
Anyone had experiences with the 1.6. 75bhp engines?
yes they are ok engines, fairly slow though and they do tend to be a little thirsty. Also they are expensive when it comes to road tax...
Yeah, I have the 1.6 100 in the estate and they are pretty heavy on fuel if you have a heavy right foot. Would think the 75bhp version might struggle a little bit with the 1500kg kerb weight (Both my estate and saloon have a listed kerb weight of 1,582 kgs according to their data panels).
Other than that, I would say check all the clocks work without hesitating etc etc. Also I would say check the sidelight bulbs haven't been replaced with aftermarket ones - mine on the estate had and they were crap compared to the stock ones I got from VW (for £3!)
Ah thanks again both! Car isnt taxed at the moment, as it was registered as a disabled persons car, so I'm hoping the garage will add tax in (for cost reasons and also if I'm not the registered owner untill v5 comes then i cant tax for another week or so)
I'm about to leave to go see it now, thanks again for all your help :)
That will be the max weight of the car fully loaded iirc, I believe the unloaded weight is something like 900kg. I could be wrong though, its just that my mondeo weighs just under 1500kg :lol:
Had a look today, test drive etc. Seemed mint!
Paid insurance deposit and hopefully picking it up tomorrow:)
I'm assuming the 75bhp version also has the small block eninge. In which case it should be easier to go low with it. My two are both big block engines so very difficult to lower!
Due to the dealer needing to tax it, i cant pick it up till today/tomorrow so I'm not too sure! Heard the sump does sit quite low..
Could you pm me with some sites for parts? Coilovers and such? Thanks alot!
For the model you have the coilovers are the same as 6N items iirc. Don't make the mistake of buying a set for a late 2000 onwards model as they will not fit.
Seats that will fit are the same as a 6N so mk3 golf, mk4/mk5 polo, seat ibiza 6k and 6k2 all fit.
Dash is the same as a 6N polo.
Basically they a mish mash of mk4 polo, 6k/6k2 ibiza with a splash of mk3 golf :-)
Edited by demolover
Essentially, a Seat Cordoba with more doors iirc
might be easier to find parts for a cordoba that fit too, coilovers, interior bits and such :)
I heard the 6n coilovers dont fit on the 6k?
Thanks for the information though buddy!
So coilovers off a Cordoba fit the 6k? I heard its the same chassis (sp), is this correct? cheers
Yes they should be fine. Think they are the same as 6n but that is why i said iirc. Most of the suspension you see advertised for that car quotes 6N too. I had the later model and that definitely had the same suspension as the same year polo hatch.
I would just go with whatever fits the seat models of that year (cordoba, ibiza). Always best to check with wherever you are buying the coilovers from though.
Sorry, didnt mean to sound a dick! Thanks alot for your help though :)
Cordoba (up to 1999 AFAIK) body parts will fit, the Cordy had a facelift in 2000 that gave it a totally different front end.
Cordoba coupe spoiler etc will fit no problems. Can even use Cordy Coupe rear quarter panels if you want to make a Polo coupe (its been done in Europe somewhere!)
The saloon is identical to the Cordoba just with different badges and a more attractive boot (no plastic bar between the rear lights).
Other n that loads of bits will fit them, just need to hunt about.
Oh, and there isnt a Haynes manual as they are such a mishmash!
Edited by Ross74h
I have been looking at the spoilers, which look really cool!
Coilover wise, id probably order off here, Phil J.
Thanks alot though :)
not a hope in hell of it being 900kgs a mk2 weighs between 730-750kgs (depedent on engine) and a 6n2 is 987-around 1100 so the saloon i'd imagine is around 1200-1300kgs.
