Electric window not going up in my 6n2
Right, had my windows down the other day and went to put them up and my passenger one didnt, took the door card off and it makes a sound and the motor moves but doesnt go up... it goes down fine though! So i have manage to push it up so its closed but stuck on where to go now.. is it a buggered motor or regulator?
Thanks for any help
broken: you can see where it clips in.. this is on the left hand side of my regulator, check both sides incase its the right hand side.
then push it back in, i used some sealant to hold it in place as it usually has a cap on the end, so just put some sealant or something on the end to hold it in place.
hope this helps anyone with the same problem
Dave
Edited by davemk5
  • Views 4.7k
I've got the same problem on my driver's side window mate, it goes down fine but goes up very slow and stops half way. Could be the window runner's or the motor
if the motors buzzing away buddy best bet is to replace the regulator may have fucked the retractor inside to pull the window up
Scroll down to part II of this guide and look at the window regulator clips. I bet, one of these has snapped!
http://forums.vwvortex.com/showthread.php?...oor-lock-module
Take the doorcard off your polo and then you will need to peel back the foam membrane to expose the regulator. Seek the metal clips and inspect. There are two.
How to remove doorcards in 6n2 (Mk5).
http://tigerstyle.co.uk/phpBB3/viewtopic.p...=10&t=32888
How to remove doorcards in 6n (Mk4)
http://www.tigerstyle.co.uk/phpBB3/viewtop...=10&t=46514
And for replacement clips (pair, driver's side) see eBay item no: 190414713106
So, you could fix this for £5 and about 2hrs work (for a first attempt!).
Best wishes,
PoloD.
Edited by PoloD
Best wishes,
PoloD.
thanks dude! will have a go tomo, looks like lots of effort :( haha
