One Leaking Polo
Hello,
After the week of rain we have just had, I went to my car to find the back carpets on both sides were just basically puddles!! now the first thought was the sunroof, because that leaks, but the seats are completely dry.
When I was driving it the other day I had a consistent drip of water on my right foot :( as well as on my head. I was basically soaked from every angle.
We have checked the battery shelf and theres ofcourse the drainage hole, but apart from that it seems ok. We don't know where else it could be coming from.
Still doesnt explain why my floor is flooded on both sides :?
Also my car is always parked on a sloping drive with the car facing upwards, don't know if this has something to do with it.
The sunroof is getting a new seal but I need to other leaks sorting before winter when my car will turn into an ice rink!!!!!
Any ideas where the leak on my foot is coming from? and the puddles on the carpets on each side?
The only thing I can think is that I don't have any seals on my windows, the one between the quarter windows and the main window. (The felt slider that the window sits in), so maybe theres too much water going down there?
Thanks.
  • Views 632
Take your door panels off and check to see what condition the plastic sheet behind it is in. I have regular trouble with my passenger side one as i've had a good few inches of water in the rear footwell (mine too is parked facing up hill).
If you're going to replace/ repair, you need to make sure that the mating faces where the sheet sticks to the door frame are perfectly clean and that no small creases, bubbles or ripples are formed. If they are, water will eventually seep back in (like mine!).
