Mk2 Badgeless Grill
So i have acquired 3-4 grills over the years and they all have badges on them. I really like the look of the badgeless grill but haven't seen any for sale.
I've heard that you can make them yourself but that involves some plastic welding. Are there any guides around of how to do it?
  • Views 950
Chop the badge out........
chop bits out of another grill.....
glue them in...
sand in flush.......
maybe a tad of filler.......
sand flush again if needs be.....
spray it .......
You now have a badgeless grill
glue them in...
spray it .......
You can do some pikey style plasstic welding with a soldering iron and strips of plastic (use parts of the same grill). mutch better than super glue. It will help if you have a variable temp sodlering iron. You want to aim for a temp that will melt the plastic without any smoke cmming from it. Oh and be sure to use a tidy mask !!
The grille on a Mk2 is so wide it will look odd without a badge in the middle, it needs something to break it up a bit. Might work on a quad headlamp grille though.
