what size plug for de-wipering the rear for my 6n polo ?
want to de wiper my polo but need to know the size of the plugs that goes in place of the wiper arm . thanks for any help :D
  • Views 892
may not be the right size but i put a 8mm rubber bung in mine from halfrauds
x2
Just forced it in, it's slightly large but you can't notice it from the outside. Just glue it in and bob's your uncle.
x2
Cool thanks guys :) sooo go for an eight mm? And do you need to glue em in ? Water proofs?
glue it in if you want mate up to you, i didn't and mines in nice a good. 8mm is a little big which then will create the water tight seal itself so you won't need to waterproof
I don't suppose you can buy the larger rubber bit from vw ??
Mine has had the wiper taken out and I have a half semi circle hole then a smaller hole in the metal work
