Fitting an OMP bucket into 6N...
Right guys,
I was under the impression a lot of the mk3 golf stuff was a direct drop in replacement for 6N models.
If i was to order OMP seat mounts for a mk3 golf, would they allow me to mount my bucket into the Polo?
  • Replies 14
  • Views 1.2k
Yep, I had OMP Mk3 Golf frames in my old 6N valver, fitted fine.
Awesome answer!
Rarely do you get a 100% spot on reliable source, but that's mint.
Daft question but, were you running an OMP bucket on your OMP frames? The only reason i ask is, my OMP bucket doesn't have mounting points at the side of the seat like some, it just has four threaded holes directly underneath the seat, would the OMP frames still work ok?
thats a very unfair and cheeky comment to make mate, the amount of top help you've had of users on here!
Apologies, i knew what i meant in my head but it didn't come out very well.
What i meant was, it's not often somebody can give you a 100% "i've done that exact task using that exact brand/item" sort of answer as there's often a lot of speculation as to what may or may not work in/on our cars.
I wasn't knocking the efforts of others on here and as you say i have received a lot of useful help before, for which i am very grateful.
:oops:
All good dude. :smile:
Awesome answer!
It depends on the frames you go for, have you got a picture of them? I'll try and dig out a picture of the ones I had, but I think generally most base mounted seats have the same spacing.
Awesome answer!
I'll get a pic of my seat and the frames on ebay i was going to go for.
The first auction is for one, the second for a pair.
These are the ones I had: http://www.ebay.co.uk/itm/OMP-R-H-SEAT-MOU...=item4cfb02982d
Yep that's the one, so that's all i need for the drivers side, just that one frame?
Yeah that's the one you need. You'll also need a sliding rail kit to fit between that and the seat though, as the eBay ad explains. HC/665 should be what you need.
Can i not just bolt it solid? Even if i wanted it solid do i still need a piece between the seat and the frame?
Here's a pic of the underneath of mine, you can just make out the four threaded holes in the corners:
303209_10150338141884024_628254023_80119
Right,
I messaged YB Racing regarding subframes etc and they gave me a rather useless response saying i can buy a slider kit if i want and that you normally use side mounts if bolting the seat rigid (clearly the above picture shows mine mounts from underneath, not the sides.
Does anyone have any other suggestions besides a slider kit? Do OMP sell rigid brackets to go between the frame and seat?
Bump
