Window winder (regulator) rear doors
Evening people!
This is my first post as just last night i got my first VW polo, a fixer upper but never mind :)
3 of the 4 windows of my 1995 1300 CL do not work :( i have decided to tackle the rear door first which has a manual winder.. when i got the door opened i noticed the window regulator winder mechanism was un repairable the cable was saverly fraying and the cogs were damaged.
How ever I've come across a snag in my little DIY job...
I cant seem to actually remove the mechanism from the door itself, removed all the bolts doesnt seem to be attached to anything just cant see how i could remove it from the small access hole in the door,
Any help would be much appreciated!
Thanks again Sam
  • Replies 8
  • Views 1.5k
Bump,
I've mananged to remove the winder mechanism from the door now propped up the window to stay in the up position where the best place to pick up a replacement, would rather go new but I'm guessing VW will want a kidney for the part :$
Hi Sam and welcome to clubpolo!
VW do sting on some parts but not on all so it might be worth asking for a price from them first.
If it does sound a bit high, try your local GSF or EuroCarParts as they often have OEM parts for trade prices.
Failing that go to the scrappy, 6n polos are 10 for a penny in most scrappies and you may find a good used replacement part for even cheaper!
Hope all goes well with the first polo.
Ash
Ash
at the risk of admitting I'm a polo noob whats a 6n? :p
s'alright bud, we were all there once!
6n is VW's Typ number for your model of polo '94-'99
it can also be referred to as a mk4
have a read up :p http://en.wikipedia.org/wiki/Volkswagen_Polo
nice :) i knew it was a mark 4 but thanks for letting me know about the 6n thing, just found my regulator on the drivers side is busted anyone know how much I'm looking at for a replacement? :):)
as my project stands... the rear manual winder is dead the front drivers side motor seems to have the cable jammed inside and the passenger i havnt loooked at but no noise at all coming from the door and the switch works... :(
In my local its easily 20 per every 6n2.
have you checked the cabling going from the door to the car? sometimes they fray.
The cable was frayed and the plastic cog was really badly messed up so replacement needed :)
