number plate screw retainers?
when i got my saloon it had the plates velcrowed on the back to change for show plates. The problem i have every time i park it in the sun the glue melts and the plates fall off. there are two square holes that I'm assuming some sort of screw retainer fits into?
if anyone can help or has any of these could you let me know cheers
  • Views 758
I am in need off the same answer, I was going to use just screws and bolts..
Edited by POvwLO
anyone? someone must have taken there number plate off before
you'll need something like this
http://www.tools-supplies.co.uk/locking-nu...20mm-1125-p.asp
to fill the holes, then you screw the plate on!
However you won't want a pack of 50 like they^ sell, my personal route to getting some would be go to a breakers and grab some, they probably wouldn't charge you too. All vw's of an 80's and 90's era should use the same type for the plate on the back when its on metal.
The other route is to get some of the double sided foam tape, thats what they use on modern cars anyway.
