Looking to buy a 9n3, what to look out for?
Hey guys
I'm looking at buying a polo 9n3 1.9 TDi 100 / 130(If I can find one!)
looking for one with about 50-60k miles on it
All cars have their weak spots so I was wondering what to look out for when going to look at a polo with this spec.
All comments appreciated
Edited by Hawkes
  • Views 751
Not sure about the engine (I know the petrols can be a little dodgy) but it's worth looking at the front rear wishbone bushes as these can wear prematurely. However, my 9n is on 95k and I'm just about to change one. Depends how they're driven to a point.
Other than that, i'v not heard any problems. The 1.4 tdi is nice, and can be mapped to 110bhp (from 75) easily with little to no effect on fuel consumption
Definitely wishbone bushes on mine went at 64k. I have the 9N 1.9TDi PD100 and its great.
Clutches and dual mass flywheels can go mine did at 72k although my car is low mileage so has probably had a lot of town driving. Power steering pumps are a common fault too so check the steering is ok.
Rear window washers break on pretty much all of them, usually just a pipe popped off.
The Diesels are pretty solid providing they are serviced regularly with the right oil.
Check the climate control works too as it has a habit of breaking and defaulting to the hottest temperature.Its the V68 motor and it costs £105 for a new one not including fitting. Aircon can be a bit dodgy too with various sensors that can go wrong.
Theres a wire underneath the gearbox called the alternator sense wire which can come loos in the diesels too due to the vibrations
Apart form that i dont think there much else which will give problems and the 1.9 PD100 is a fantastic engine I've seen over 70mpg out of mine on long trips and I'm sure a PD130 with a 6 speed box could get more.
