Rusty arches
I have a small amount of rust round each rear arch and a spot on the passenger door! could somebody give me a rough estimate of what it costs in your experience to get this sorted and painted?? I'm desperate to start putting my stamp on her but want the bodywork to be as near to perfect first!! :-o
cheers!!
p.s. I'm in lancaster if anyone knows a good place locally to get this done!!
  • Views 1.2k
Depends fully on how good a job you want done.
As with anything (in most cases) you get what you pay for.
How big is the rust on the arches? What size spot etc?
Normally a small spot on the surface can be a substantial size spot once the paints removed.
Thanks for replying!! One arch has about 10cm of rust round it and the other has other 5cm. The spot on the passenger door is only the size of a fingerprint! I'm looking to do this well once so i want the best job possible!! what do you reckon?
cheers
honestly its best to ask at some bodyshops that you trust to work on your car , some are dearer than others and depends what region etc
chances are it will be £150 a panel or more , then depending where the marks are they may need to blend the paint into the door
:shock: as a student numbers like that are brutal lol. I will go and get a quote this afternoon!! will post back here soon!!
cheers
Went to the local ford body shop - meant to be the best in the area! They quoted me £240 for both arches - £150 labour, £50 materials and the rest VAT. Does not sound bad going and I'm guessing that the finish these guys will do should be quality! Now just got to find the cash :-)
Cheers for your thoughts guys!!
depends on the colour of your car aswell. if its a fairly easy colour to blend then it'll be cheaper than a more difficult panel that will require more painting :-)
My polos flash red. dont know if that helped the deal or not but the price is still genius!! 8-)
i'd ask to see some of the work they have done. decide if your happy with it or not.
That should help as it doesent have lacquer so less cost :-)
Awesome!! I will ask! I can't afford to do it until after xmas being a student and all :? !! any recommendations on preserving my arches through the winter and the salt until I can get this done??
