whats the proper way to fit mk3 gt arches?
So hopefully i'll be fitting my gt arches soon :-D And i've been wondering...
Whats the proper way to fit them?
The set came already removed from the original car they were on and there were still a few fastenings in the arches.
The fronts had what looked like pop rivets, so i'm guessing the correct size pop rivets for these? and then some foam trim tape for the bump strip section?
However the rears had plastic push in studs, the head was textured like the bumpers etc to match, and the shaft had small plastic teeth to lock it in.
So basically, should i try and get hold of more of these? In which case would they work on the front aswell?
As for the sill trims, same question really. Pop rivets? And these have a black mastic along the top, should this be replaced?
Actually, to summarise, how should they be fitted?/would they have been fitted when new?
Thanks for any help in advance 8-)
  • Views 702
