6n/2 5 stud hub
Hi all, who's ever thought of changing an earlier model polo into a five stud hub to avoid having to run adaptors/spacers and subsequent stretch tyres to fit 5 stud wheels? Was thinking maybe mk3 golf gti hubs (driveshaft permitting) and maybe 9n3 rear beam or mk3 golf gti hubs attached to the trailing arms. I'm a fan of 'tuck' but also a fan of some later model polo/golf wheels
Had a quick search and it hasn't thrown up any results, but having seen some of the weird and wonderful projects on here surely someone has had a stab at it. I might be up for it if it's not too much hassle as mk3 golf parts are piss cheap
What do we reckon?
Edited by dt_
  • Replies 19
  • Views 3.4k
I'd assume so as you could run the G60 setup on the front, not sure about the backs and driveshaft fitment mind, though if you're only going to do it to fit wheels, it might not be worth as adaptors are always the cheaper option and can be made to get tuck rather than poke
G60's are 4 stud...
Is adaptors the cheaper option? What are they, say two hundred for a full set, I dare say that mk3 hubs can be had for less if I do the fitting (and presuming they are a straight swap. Could fit vr6 brakes which would be pretty cool
G60's are 4 stud...
Arse, I always get VR and G60 setup confused, but meh its a mk3 golf who cares :lol:
Indeed it would but you'd probably having to encounter massive scene tax on VR brake setups, tbh it could be a straight swap but like I said earlier about the drive shafts plus and its a helluva lot of work just to fit 5 stud wheels
Hmm can't see scene tax affecting new replacement parts... Think it could be interesting, will have to look into it, is t easy to whip the drums off and fit discs?
Now for the really crazy stuff... What about a g40 engine in a 6n2, I've seen it in a 6n...
Surely £175 - £200 on adaptors is going to be cheaper than hubs, discs, calipers, carriers, pads and bigger lines for the front, you need to either get an rear axle off a GTI or specced TDI mk5 or off the golf itself which again won't be cheap...
G40 6n2 has been done, search for polo6n2G40's thread (think its in the mk5 gallery or photo gallery) Oli did a really tidy conversion
I reckon i could 5 stud a 6n for less than £100.
If it was used parts yes, but dt_ is on about new replacement parts
I bought a set of 5 stud VR6 rear disks from halfords for £10, VR6 replacement disks and pads aint dear. I stand by my £100 comment, including new disks and pads (as long as i'm allowed to call in a couple favours as I know where there's some 5 stud running gear lying about)
Calipers and carriers ain't cheap though dude, not all of us know people with parts piles :lol:
What about pressing a five stud drive flange into the standard hub assuming it's the same diameter bearing? Hmm, mabe a five stud drum hub from a fabia?
Guna have a gander for that g40 thread, sounds cool
mk3 VR6 holds the key, the hub will press into the 16v polo bearing carrier, backs are a straight bolt on.
Yeah the rear stub axles will bolt straight on, it's not hard to find a MK3 Golf in either VR6 or either 16v or 8v GTi form (even the 8v GTi had the five bolt hubs).
I've got a mk3 golf and recently changed the front and rear set up to a vr6 arrangement. I got the whole lot for the front for £120. I needed driveshafts, wishbones, arb, hubs, carriers etc. For a 6n polo you will definately need wishbones (lower ball joints are different), hubs, and possibly the driveshafts. On my mk3 the standard flanges (diff end) on the driveshafts were different to the vr6 ones so had to swap the ends over. I think the 6n driveshafts are the same as standard mk3 golfs so will probably need the vr6 driveshafts too. I'm honestly not sure about the rears. The whole rear beam was a straight on my golf for the vr6 one but I'm not sure about the 6n (6n is possibly thinner than golf so may make it widetrack at rear). I should imagine the stub axles off a vr6 will bolt straight on to the 6n beam though.
Hope that helps!
EDIT: The vr6 brakes also stop on a penny!! Well worth the upgrade from 6n ones!!
Edited by dansharpy
Just put VR6 outer CV's on the polo shafts.
Use polo 1.4 16v setup but with the golf 5 stud hubs pressed into the 1.4 16v bearing carrier. Polo 1.4 16v shafts with golf outer CV's... Sorted
Yeah sorry, thats what i was trying to say!!
You've got a funny way of saying it if you where trying to say swop the drive flanges and cv's.... :lol:
I meant thats what i was trying to say about the driveshafts!! :p
Edited by dansharpy
obviously need 280 or 288 5 stud brakes too
can you not buy new 4 stud hubs and have them welded and redrilled to 5 stud?
