Tired interior
The interior of my loon is severly faded. It's blue, but on the back of the head rests it's faded to grey. I was going to re-cover the seats, but its a limited run and seems a shame to fuck them off just for the sake of if. So I just want to add the colour back. However, dying isn't an option as it a blue/White check pattern. Is there any thing I can use to restore the colour? Is there a dye that can be applied to small areas?
Also the bolster has worn a bit on the drivers side (surprise!). Anyone know if this can be repaired without having to find the material? It's not ripped or torn, but more threadbare
  • Views 674
unfortunately i doubt theres a simple option, even if you painted the dye on individually to the sections it would still spread.
As for the bolster, again without replacing the material i doubt theres much you can do, if the bolsters saggy replacing the foam behind can help.
What about steam cleaning it to freashen it up? It might bring the colours out a bit too.
I thought that about applying the dye, and how it would spread. Was thinking if there was an oil-like alternative that may bring the colour out (much like re-oiling wood).
The bolster is saggy, and I'm on the look out for new ones. I'm going to wash the fronts to bring the colors back. The fading is really only on the back of the head rests where I've left it in the sun all year. Grrr!
