service oil light on 6n2?
hi guys, where the trip mileage is on the dials it now flashes saying service oil? whats this mean? give the car an oil change? its a 6n2 1.4 8v :) thanks in advance.
  • Replies 9
  • Views 8.2k
yeah all it is mate is to let you know its time for an oil service, get it done and the garage will be able to turn it off once its done :)
It probably means that its due a service. Check your service book and see when it was last done, if its over 10k miles ago or over a year ago then it will need a service. If it has been serviced recently then it might just be that they forgot to reset it.
thanks for the advice :) i usually do services myself so il change the oil and get garage to reset it.... will they charge to reset it?
Tells you how to reset the service counter in the manual, basically hold in mileage reset button, turn ignition on (don't start car) and wait for display to show ------, let go of the mileage reset and that clears it :-)
Make sure ignition is off press and hold the the button under the mileage, turn the ignition on keep the button pressed down untill you see something like '---' then let go of the button. Turn ignition back on and it will be reset.
Beat me to it jon :(
thanks mate this helps :) could do with some more advice aswell please if you could...just bought some mims 1900 15inch and 7.5j just wondering what size tyres would be best?? :D
195/45/15 will see you well matey :-D
cheers mate :D much appreciated.
