Breaking Mk3 Coupe - Leeds
Most parts available - Mk3 (2f) Coupe.
1300 (non GT) engine - bottom end good, full top end rebuild, GT cam, cleaned and painted.
Good 5 speed gearbox & associated parts
80mm lowering springs
Front disks & pads are only about 1000 miles old
Rear beam with new wheelbearings both sides
Smoothed Tailgate
Let me know what you need and i'll sort it out.
  • Replies 31
  • Views 1.2k
have you any pics mate??
koolspot@hotmail.co.uk
nice1
How much for the front springs mate?
£20 for springs.
Only got these pics
Forgot there's a set of GT steelies too.
leccy plug for the in-tank pump? or ideally full fuel pump loom, back to dashboard
Edited by grungeisdead
£20 for springs.
Where abouts in leeds are you? If my car gets through the MOT without many problems I'll take them, will let you know later tonight.
Yep that shouldn't be a problem.
£20 for springs.
I'm just off Jct 46 of the M1 (Colton). Work in Wakey though.
how much for the gt cam and pulley posted?
It's in the engine.
Are the brake lines nice and solid? No corrosion or anything?
Smoothed Tailgate
how many miles has the engine done,& how much for the engine and box? :-)
Not sure about brake lines, you wanting the solids or flexy's?
Will check mileage tonight.
okey doky 8-)
any news on the engine & box m8? :-)
Bottom end has done 100k, but hasn't been started since the top end rebuild. Had a new clutch about 13,000 ago.
Are the front seats in good condition? If soo how much? I'm only in pudsey. Dan 07887901985
have you got the downpipe with lambda sensor fitted?
did the front springs go? if not i'll take them
They are apart from one small tear in the rear of the passenger seat, which would glue together. Would like £30 for them.
Yep - nearly new sensor too - £25?
Nope they haven't gone, PM me for gaypal/collection details.
how much we talkin then engine complete with gearbox? ;)
How much for the thermostat housing on the side of the engine the thing that all the water pipes attach to... Could do with it posting aswell if thats not to much trouble
Ill take the seats 30quid thursday... Also need a steering wheel column the bit that holds the barral and wires as mines moves and has far too much play in it... And also a rubber strip that guides the window and seals it... Also the rear seats?with brakets... Cheers Dan 07887901985
Parts sold so far:
Seatbelts/Clips/parcel shelf supports
Front springs
Gearbox/Speedo Cable
Everything else still available.
How much for the door cards and your number plate light holders with the conection parts.
I'll have to check condition and let you know.
