Check your Brochure for me - Polo Estate (6KV) or Classic - 97-02
Do you have a Brochure for the Polo Estate (6KV) 1997 - 2002 - or maybe Polo Classic ???? [or even Cordoba Vario].
If so maybe you could look something up for me.
If you look in the Wanted ads section you can see that I am looking for a tailgate for my 2001 Polo Estate - and I want it in Flash Red so that I don't need to get it painted (don't want much - do I ????).
Until yesterday I believed that ALL red (non-metalic) Polo Estates were Flash Red (LP3G), regardless of year, but I now know that some earlier ones are Tornado Red (LY3D).
To help my search I need to know which years/registrations used each red colour.
I have a copy of The Polo Estate 2001 Model Year brochure (that is what the front cover says - back cover says Issue 1 - Feb 2001) and on the Exterior Paintwork options page it lists Flash Red (order code D8) or Rustic Red (4M) but that is metallic.
If you have any other year/issue brochure could you take a look, and tell me the Red options.
I would also be interested to hear from anyone with Polo Classic brochures - because pretty sure they would offer the same colours as the Estate - but Hatchback Polos will definitely have different options, so that would not be much help.
If you have a Seat Cordoba Vario brochure I would also be interested - because I am guessing that I can probably use the tailgate from one of those.
Before anyone tells me - I know that I can ask potential sellers to look at the Build Spec label near the spare wheel, and that it has the paint code on it - only trouble is that most breakers rip off all the panels, and crush the shell, without making a note of the paint code - and trying to describe the difference between Flash and Tornado reds is worse than impossible.
If you don't have brochures, but you are an expert on paint codes - obviously I would like to hear from you. In an ideal world I would like to know the VIN No at which it swapped from Tornado to Flash.
  • Views 816
Hi there
Do you still need this information? If so, I'll take a look through my brochure collection.
Rich
polodriver.com
Thanks for asking.
I am still looking for a tailgate - so it would be helpful to track down when the change happened.
So far I have only got one further bit of info from brochures - someone with a June 1998 Estate brochure told me it lists Tornado Red as the non-metallic red.
So now I know I need to check which red - but I only know it changed somewhere between June 1998 and Feb 2001.
If you have any Estate (or even Classic) brochures between those dates I would be pleased to hear which red they list.
Many thanks
Thanks for asking.
Many thanks
Hello there
Here's what I found (Polo estate):
- 09/98 Tornado Red
- 09/99 Tornado Red
- 01/00 Flash Red (Polo Saloon)
- 05/00 Flash Red (Polo Saloon)
- 01/00 Flash Red
- 05/00 Flash Red
- 02/01 Flash Red
So, it appears that it was January 2000 or thereabouts, I think!
Hope that helps.
Rich
polodriver.com
Hi Rich - thanks very much for your help.
That is just the info I need - and not only is it very helpful - but conveniently it is also easy to remember - if it was built this millennium it should match.
John
