Malaga Red's Arctic Blue Coupe
Why am i only just spoting this thread! Looks sweet mate! Very well done you! :)
  • Replies 445
  • Views 60.8k
  • Nice! Clocks look smart mate.
  • might buy it, lower it and re-sell it. I'll weld them lowering springs in too so it cannot be un-done easily
  • malaga red
    malaga red
    Its officially the end of an era folks. Watched this drive away from me and disappear into the distance today . Goodbye M386 JOA. And Goodbye Polo's. Its good that I got near enough the price I wanted
It's a polo not a Bentley just wack a 60/40 on lol!
Gaz coilovers are on my list but I just want to see this low soon! :ninja:
Better off with PhilJ specials than Gaz from what Nick has to say about his :lol:
Mine arnt so bad after essentially speccing the kit myself lol.
So, i have a job now. Not much of a job (8 hours), but i'm getting payed. Should be seeing some (slow) progress on this.
Lets get my build thread back to a build thread, not a 'are you lowering it yet?' thread.
What sort of prices would you be looking at for a specced kit Harris. Pm me. H&R's are £330ish, so dont want to spend alot more than that. With my current work it will take an age to save up for them anyway :lol:
Do you want me to spec you a kit Dan for what you want instead of an off the shelf one?
Have contacts at billstein & eibach so is doable, billstein make dampers to suit already so would be a case of swapping some shims and then eibach may already offer a spring but I believe I may be able to get custom ones reasonably priced too. Depends what you'd want to spend on a kit.
I've got eilbach springs on mine! lol
Everyone used to rave about the H&R springs and shocks for a mk3 pretty sure they are less than £330
is this not lowered yet.... :) hahaha
lol Jake..
atleast he's connected a connector. More progress than you :lol:
lol Jake..
2 years to put an AFH in....
Car looks so fresh, in flesh ;)
Depends how far I went with it dude. Damper tuning with billstein would cost me £500 a day to get a setting so it might be more of a long term thing I'm looking at - but I don't think it's worth it cause if it's more than £200 for suspension that's far to expensive for most on the scene lol.
I'll repeat the excellent words MartinB said to me at a rolling road day:
"I'd like to congratulate you on your choice of grille sir."
Looks ace. Keep it up!
pahahahahahahahaa! Excellent!
Can't beat an OEM front end, all you're missing now is headlamp washers ;)
I am down to two Hella grilles now. One mk2f/mk3 BNIB and one mk1 BNIB too!
Keep OEMing, looking lovely!
edit: mk3 fogs aren't the brightest fogs out there. Keep the original loom. A relayed loom melted my holders and I think b-shaw had the same problem too.
Nope. Cant beat it :) On the lookout for the washers if you know of any? And i knew about the fog relay and the melting, thats why i went with the factory wiring. They dont like the extra heat created by more current ;)
how does one re-create this without original wiring? cant use mine cus A, ones broke and B, ill melt the other.
What wattage bulbs are you using?
dunno, standard bulbs lol
Easy mate. I made a loom before i bought the fogs, but they surprised me by coming witha perfect OEM loom. Cut the loom up for the cable now though, as i'm cheap and used it for my grille wiring :lol: I do have all the connectors though including one for the scuttle and two brand new ones for the fogs, If you want them. Wont be free though :lol:
Couldnt get mine to work using original switch. was the idea but failed so used relay.
doubt ill even bother, fucked me off before. I'll just have the lamps there for show :lol:
Myself and a couple of mates ran eibach springs and adjustable koni shocks on mk2s and a mk3. Was about a 40mm drop and handle well. Add some powerflex bushed and its a great handling/ride/stance compromise. This was a few (well over 10) years ago now. Running Gaz coilies now though.
  • 5 weeks later...
Not much happened to this for a while, but should be some progress pretty soon as I am about to order suspension in the next few weeks, along with a new exhaust system (need to get this priced up) and different wheels and tyres (don't know what yet, but want a change :lol:). Started to give the paint a really good clean as hasn't had a proper going over since last July and was full of contaminants (felt a bit rough). Got to work with the Clay Bar, polish, pre wax and Carnauba wax. Only done the bonnet and roof so far, but looking shiny. Lovely deep shine and reflections and is super smooth.
The result 8-) :
Proper updates coming soon :-)
First major thing in a while. Spent a bit of money today. Cruised over to Kingswinford Tyres and had a power flow stainless exhaust made. Got a CAT back system with 3" inward rolled tail pipe.
And a pic of the whole car. Cleaned it yesterday for the first time in a week:
Pretty happy with the system. Could be a little higher where it goes under the rear beam, but its made now and other than that spot on. Its nice and quiet, not much noisier than standard. The car has more torque, so pulls better, especially up hill at motorway speeds. Feels a little bit pokier when accelerating too. If anything its probably quieter than the standard system at 70 :-)
New (well old) wheels turned up this morning too, so its been a good day in Polo land. Wasn't going to put wheel pics up until they were finished but heres a preview:
Can you tell what they are?
If you guessed Sebrings then your correct. Tyres are all shot and are being chucked. 195 50 are too big anyway. Wheels are all straight with minimal curbing and have all the caps with all clips intact, a rare thing in itself. Been after a set of 15's for a while and was originally looking for 15" RA's, but saw a few people on here were going with them. These came up at a decent price so I just bought them. Don't see many polo's running these so will be a bit different and still be OEM.
Any reason for going for that tip ? I think the straight cut pipes suit older cars better imo :)
I chose that tip as it was what I liked the best and was one of the smallest/ most subtle they had :-).
wish mine were a straight cut, altho i bet ill end up with a full custom system soon as mines ones taking a mad beating already.
I like this tho dan, as you say its nice and subtle.. hardly tell its not standard
Just need lows now mate
We are gunna cut you are springs at poloshow if you dont lower it before.
Not lowered. Nothings even been bought. The more you lot keep on, the longer it takes :lol: Spent out for this month now anyway. So no chance of a change in ride height for polo show.
Was driving near the peak district this weekend and it just drives so well at the standard height, and had a mate with me for a 12 mile round trip from camp site to sainsburys and he said it drove really well, as did everyone else that's been in it. So much better than my lowered one that I took there last year :-). Scared of ruining it as its so good. Exhaust made a big difference today. Was driving up a few long hills on the motorway, something I have struggled with in the past. Now I can be doing 75 in the outside lane and its still pulling. Doesn't lose speed at all :-D.
I heard your exhaust came off dude , what happened?
One of the rubbers snapped on the way to polo show. I didn't notice and it was bouncing around and now its blowing because of it :-( . Taking it back this week. Its currently held on with a cable tie and a jubilee clip. Cable tie hasn't melted which was a surprise after 2 hours of motorway driving.
