Big brake set up 6n
I'm breaking my 6n 16v and have removed my big brake conversion. For sale is the entire hub assembly including 280mm grooved discs with red calipers and carriers, along with braided lines and brand new mintex pads. One of the bleed nipples was damaged and was professionally repaired and plugged. Located in Southport PR9.
£120 posted.
Edited by _Nick_
  • Replies 10
  • Views 708
I'm breaking my 6n 16v and have removed my big brake conversion. For sale is the entire hub assembly including 288mm grooved discs with red calipers and carriers, along with braided lines and brand new mintex pads. One of the bleed nipples was damaged and was professionally repaired and plugged.
£120 posted.
Hi you where are you based?
I how much posted to po8
Would this fit my mk2 caddy do you know? AKA a polo mk4 classic?
Are they not 280mm? I thought cars with 288mm discs were all 5 stud.
Hi i'm interested if these are still for sale? do you know wht they came off andif they are using the 6n hubs?
cheers, J.
Bump
Are these g60 brakes?
Bump
Bump
Are these still for sale?
Interested.
PM'd
