MK3 DIM DIP Light
Can anyone make me some Photos, or a Video Of The DIM DIP Light of the MK3 ?
Also Some Detailpics of the Harness, with the conections, and the Position of the Resistor would be nice.
Reason: I´m From Germany, ans think, it would me a nice Touch, to add This Feature 8-)
  • Replies 22
  • Views 2.1k
was it not a standard item on the LHD models then?
Makes me wonder why they fitted them on the uk models tbh.
no, because, Dim Dip is/was a UK invention :-D
Edited by Polo4l
odd thing to have as UK only especially as certain EU mainland countries at the time ruled that cars had to travel with lights on, Sweden being the most obvious, while in this country driving in thick fog/heavy rain with no lights still seems acceptable.
I like that most new cars have running lights that cant be switched off.
Not more odd than driving on the other side :lol:
Can you make me some Pics of this Stuff ?
Can get a pic of the resistor in the morning. ill grab a screen of the wiring diagram as well.
Awesome!
Can you get me also a pic, how the headlight look like in the Dim dip mode ?
Can't on mine as its all unplugged as I've got HID's but ill get a pic of the mk2 which also has dim dip if thats any use.
Yes, shure!
Everything failed here today sorry. Cant even stand up outside never mind take photo's. :lol:
item 10 is the unit.
but i cant find where it connects in the rest of the loom.
Everything failed here today sorry. Cant even stand up outside never mind take photo's. lol.gif
Haha!
Thats as far i´am :D
There is also a extra Lighting Switch for it.
How do you Activte the Dim Dip ? Does this switch habe 4 Points ? ( Off, Parking Light, Dim Dip, normal headlight )?
Cheers 4L
Edited by Polo4l
it just operates on the first setting with ign/engine on
so engine off...side lights only , ign on sidelights and the headlamp bulbs half on
anything ?
Give me a few mins.
Could only get pics of the plug and resistor pack...
Wire loops up and into a grommet and goes behind the dashboard.
What is dim dip?!
when you have your sidelights on with the engine running the dip beam of the bulb is running at about 1/2 power.
Don´t all UK Mk2 and MK3´s have it as standart?
I Seams to me, that the grommet is ja same for the heated washer jets, That is also what EPC tells. Good.
Cable colors are yellow and yellow/black?
Do you have a Wiring diagramm, or do you know hab it is wired up?
And can you please also take me a pic from the rear of the lightswitch
This is a German one, does the Dim-Dip Lightswitches have more Conection ?
Polo4L
Uk ones have more pins, hope that helps a bit? Cheers Mark
Edited by big burt
Thanks!
56D ?
Normaly thats the pin code for headlamp Flasher - lol ?
Hm Still no Pic, how it look with dimmed Dip´s in the Headlight ? :shock:
Does nobody use this funktion anymore ?
What Resistance does the Resistor have ?
4L
got a resistor, headlight switch and a old mk3 dash loom if it helps? but you would need the wee bracket it pop rivets to the inner wing.
Sounds nice! Richard. that wee bracket, would not be a problem, i think it is still aviable, and not as expensive.
But i Still want so se a picture, of a MK3 with enabled DimDip, so see, if i want it :D
Edited by Polo4l
