headlamp washer jets
sorry if this is the wrong place to put it but i could'nt decide whether it should go in engine technical, or electrical.... But anyway i decided here.
Basically I'm fiting HID's to my 6n, yes i know there illegal but i am in the process of making my own custom auto adjusting system for legal road use, but anyway to the question in hand.
Just wondering if anyone has fitted there own headlamp washers and if so what did they use for this?? If there's no ideas i am just going to use standard washer jets fited into the bumper but its just the angle I'm worried may not sit right so wondering if anyone has done this and what did they use?
all help aprreciated, thanks in advance
  • Replies 13
  • Views 1.2k
Have a look at land/range rover washer jets. Its what I intend to use. The discovery ones might be better suited to the 6ns bumper.
Then you just need an anti-syphon valve and second tank/pump setup.
Btw if your suspension is stiff enough you don't need a leveling device. Lol
ah cheers dude il have a look into it :-) i didn't know about the suspension side of it.... Just been wasting my time then :-D not far off completing the setup aswell, even though its not on the car.
i was planning on just fitting T pieces into the original washer piping then routing it to the new jets, do you recon that'll work?
also where you putting you are extra washer bottle as there doesn't seem to be alot of room?
and lastly lol (apologies for all the questions) what colour rating you going for?
I'm thinking 8k because its 10k that blinds people iirc isn't it?
cheers for the help
vw do a set for your car could retro fit them but wouldnt be cheep about £120 i recon.
as sweet as they'd probably look, I'm tight so more likely to get so TD5's for £20
4300k is bright white (brightest and is OEM in some brands), 6k (OEM in most brands) White with flash of blue, 8k (OEM in very few cars) Blue tint with flash of white, 10k blue (dont even bother :lol:)
Anything higher than 6k starts to stand out really and after 6k the light gets bluer and dimmer.
may have to go for 6k then me thinks
I've got 8000K, and ALOAD of people i know have them. Never failed an MOT because of those supposed "rules".
Rules are changing. and a particular fail item is the colour of the output, tester decides its too blue then its a fail.
all about opinion though,some may pass some may fail
Yep. you get the tester on a day when his wife said "not this morning darling" and there's your fail. :lol:
The new testing rules have more holes than a Swiss cheese.
to be fair my car gets MOT'd by a lad at work
Edit: not green sheets nowerdays my bad, he'll cross my palm with the new bland looking sheet
Edited by Cymro
Mines green. :lol:
to be fair my car gets MOT'd by a lad at work so as long as i cross his palm with silver he crosses mine with a green sheet
Public forum mate, think abit before you type and dont be writing that your car has a potential dodgy MOT. KTHXBI
true that
