6n2 gear gaiter
hw do u change a gear gaiter for the 6n2?? thank u for any that can help!! :-o
  • Views 1.6k
Unclip the bottom from the handbrake surround thing, just get a finger under and work round till it's loose; then pull up on the gearstick hard.. It just pulls off.
You can open/loosen the clip that hold the knob on, and crimp it back tight afterwards.
You also need to pry off the plastic serrated ring that holds the gaiter to the knob, easy enough.
Edited by Stupid Monkey
