according to haynes
i have been looking in my haynes book for mk3 polo and it doesn't make sence... i normally only use haynes for reference. and this proves why..... i doesn't talk about the NZ engine and the specs don't make sense to me.
engine codes say
AAU - 1040cc. single point inj. catalyst
AAV - 1272cc Single point inj. catalyst (reads the same as NZ, but NZ is multi point)
3F - 1272cc. Multi point inj. catalyst (GT engine)
PY - 1272cc Multi point inj. supercharged, catalyst
compretion ratio's
AAV - 9:5:1 (same as NZ)
3F - 10.0.1 (same as GT)
ignition systen (general)
AAU, AAV - Bosch Mono-Motronic (my NZ uses this)
3F, PY - Digifant (GT and G40)
the AAV points towards the NZ in every way BUT the engine codes section says its a single point inj. am i being stupid, is my NZ somehow a rlly slow GT or has haynes got it wrong!!!
Thanx
vDubLeics
  • Views 811
simply put the NZ is an AAV with multipoint injection.
55hp stock on both
I thought the nz used digijet , its an oddball though :lol: , is multipoint like a GT uses smaller inlet manifold same as a G40 , wide open switch on the throttle body and a weird 6 pin coil, i have a Peter Russek manual which covers some of ths engine , Mark
I always thought NZ's were 65 hp, slightly more than the 1.3 spi with 55 hp, and slightly less than the GT with 75 hp.
Nope, 55hp
yeah the book bhp is 55 bhp... but as standard they made more than that. My ropey, unserviced one made 62bhp..
