Leaking door seals
I have Nov 2004 polo and am getting water ingress from the top of the drivers door. Rubber door seals seem to have failed -water tracks along top of interior seal & runs down plastic cover of window/door frame into fuse panel and ends up soaking floor. Has anyone else had this problem - are door seal failures common and can anything be done to fix other than replacing the door and frame rubbers.
Popular Days
I have an earlier Polo (year 2000, 6N2 Polo 1.4 Tdi) and I suspect I have the same problem. Unlike kwpolo, I haven't diagnosed how the water gets in. With apologies to kwpolo for widening the theme of the thread --
I have condensation that forms quite a thick layer of ice inside the windscreen when temperatures drop. As a result, I can't go anywhere for the 10 or 15 minutes it takes to melt the ice.
In warmer temperatures, such as now, I think I can feel a little dampness in the passenger footwell and greater dampness in the driver's footwell. I'm not 100% sure of this, because it is also where my (wet?) feet have been. The dampness in the footwells is still there one week later if the car is unused, though.
On one occasion a couple of months ago, I had dampness on the left-hand side of the boot carpet -- but this might not be the culprit because there has been no repeat. The condensation is a constant, though, and at this time of year it is a pain because it freezes.
Extra fact: my car has an electric sunroof. If I sit in it when a hose is played over the car in a "hand car wash", I see spots of moisture on the front passenger seat. The rest of the time, however, the seat is dry.
Short-term question: am I safe to use deicer on the inside of the windscreen? Will it damage the dashboard plastics?
Real question: where does water get into Polos of this generation and what can be done?
Yours in hope...
