mk1 polo seats
hi newby here , i have bought my a daughter a 1979 polo and its in mid resto but i desperately need seats or covers. will other early vw seats fit any help will be greatly appreciated by dad dedperate now not to loose his cool standing with daughter thanks
  • Views 2k
Welcome.
Seats from mk2/3 will fit the front, not sure on the rears, there might be others that fit from other VW's but I'm not sure which ones.
If you know someone thats a good welder than you can make a frame and any seat can be made to fit.
Welcome.
thanks for the help
A possible solution for the rears is to strip the material off them, and then use fabric from the rears of a Mk2/3. Although not perfect, it may do the job
golf gti fabric/padding :thumbsup: looked pimp in mine
the fronts on mk1's and early mk2's had the seat slider realease on the opposite side, therefore the lever won't work for sliding them if you fit later mk2 or mk3 seats, they still fit and lock into place though, you just need to reach under to move them.
I've got mk3 seats in my early mk2 and it doesn't fuss me.
However the frames should be the same, therefore you could remove foam and material and refit etc.
As for rears i would have thought mk2 or mk3 seats should fit? (non split) Purely because the they were all based on the same floorpan, and the fuel tanks will interchange, that sits under the seat...
I'd say your best bet would be to get the seats out of a mk3 or mk2 and go for that
yeah, if all fails then just swap the padding/cloths over to the mk1 frames :D
