rust .. rust RUST !
Hope this is in the right section brought a car a couple of weeks ago not its not bad for the price i payed for it ! however there is a patch of rust on the rear quarter divers side arch .. the rust looks only to be surface rust as there is no bubbling or holes behind it , i wanna to go for a clean white look for my car and its stopping that !
i was thinking section the arch off around that particular area grind down to bare metal , treat it fibre glass it , filler it and then I'm getting it sprayed at a garage along with a few other bits is that the best thing to do ?? NEED AS MUCH ADVISE AS POSSIBLE
( i know the seal has gone too but i dont think theres much you can do about that )
392160_10150444777274740_603124739_10457
308112_10150444790154740_603124739_10457
  • Views 1k
Just do what I'm gonna do...replace it.
Managed to find somewhere that does rear arches for £21+ vat each.
I'm just gonna cut it all out and start a fresh.
Plus when I do it, I'm not gonna be fibreglassing the join...straight up old school lead loading haha.
Edited by BigSexyRob
ok dude wheres that they do it online if they do ill just get it welded in ??
this is not a dig at you mate but iv been on quite a few car fourms and this seems to me thats its a very .. slow progress forum if you get me i dont know if I'm not providing enough information or I'm posting things in the wrong section i just thought a lot of people had vw polo's theres a lot about so the forum would be quite active ? regards !
nah, its a local parts place to me and the price is TO ME.
as i work in a bodyshop i get ALL my parts cheaper [cause of works discount ranging from 10-30% off]
tbh...6n's are notorious for rear arch rot so i wouldve expected more comments.
bad time of year to be tackling rust really
clean it up with a wire wheel and see if you can get all the rust pits back to clean metal , if you can etch or zinc primer then paint should make it last a bit longer
if its a hole , dent the edges in a bit and fibre glass it , filler , primer and paint , and try to seal the rear side as well
not as good as a new panel...but something you can diy
