Bonnet mechanism
I've had a rattle coming from the left side of my dash for yonks now and finally think i've worked it out . the left side of my bonnet ( nearest windscreen ) is a bit loose there for rattling the bonnet and pissing me reeeeeeeeeeeeeeeeeeeet off lol. but its seems to be the mechanism what attaches under the bulkhead what is loose. Cant really see much but looks like's only a clip holding it on :S , its the Bent bit what attaches to the bonnet which allows it to swivvle up and down . How can i tighten this or stop the rattling .. ill get a pic tonight if it helps .
Jamie.
  • 1 year later...
Jamie did you sort this dude? Mines got the exact same rattle and it's been doing my nut in for 2+ years. Where the arm attaches to the car is loose like yours.
Etches
surely it shouldn't rattle if its bolted to the bonnet properly? tried pushing on bits of your dash when going along to see if the rattle stops?
Nah Eric, I've had the entire dash out its the bonnet rattling. I can see the left tip (from the drivers seat) vibrating etc. It vibrates on idle too, I've tested that out by holding the bonnet whilst a passenger is in and it stops the noise. Also with the bonnet on the stand it can be moved on the car hinge slightly back and forward creating the same pitch noise.
Has anyone had any experience with this issue?
