Will a 5 door cupra interior fit straight into 3 door 6n?
Straight forward question really, just wondering if a 5 door cupra interior will go straight in to a 6n 3 door or if it needs any modifications
Edited by smithyjok
  • Replies 10
seats will fit, but if the front seats don't have the handle to put it forward, it'll be a ball ache, door cards will not fit at all.
Thanks for your help, I did take into consideration th handles but I don't use the rear anyway as it scrubs with any passengers
save money and just buy the front seats 8-)
Just so you know i took your advice and no they don't fit! So please don't give out advice if you don't know, thanks
should have fitted - can you give reason to why they didnt for other peoples future reference
No problem, the rear bench is too big and doesn't fit, and fronts are too small on doesn't fit on the runners
Depends which Cupra its from. What year were the seats out of? I'm sure mk1 to mk3 ibiza seats fit. Correct me if I'm wrong.
hello again mate, I was absolutely certain they were a straight fit (front) and I have been searching on here for the past 15 mins and everyone says its a straight fit. the rear seats need the brackets taking off the bottom. I knew the answer, just do a search and it will tell you how to fit them unless you got them from a cupra 2002-onwards.
Right, i'm not taking the piss, i need some input here. Please.
Why TF would someone drive a ton of excess metal about and not cater for rear passengers? Are you too POOF to ride a bike? Not even a VR6-TURBO is gonna counter against a 1.8i with that weight penalty.
If i owned a Leon and couldn't give my kids a lift i'd need professional help.
Get a fucking MR2 or MX5 whilst your hair still needs cutting!
