6n 6n2 power windows :-( anyone any ideas ?
Well guys this may be a silly question lol so sorry if it is does anyone know if the 6ns with non power windows have the output in the door loom for power widows ????
  • Replies 9
Anyone help wit this
Depending on your model it may have it on the car side(ie where the door loom connects to) , but you'd have to get the door loom out of a car with power windows.
Although it is just 2 wires from the a pillar red and brown Iiirc.
If it doesnot have the wiring behind the dash, it's not a problem, as you could make up the loom to the fusebox and the switches, or cut as much off of a scrap car as possible then patch up the rest.
Hth
Hth
See Am putting 6n2 doors on my 6n and was hoping in already had the input for powers windows in the door loom on the car side
Ah, I see.
Does your car have electtric window already?
The 6n2 has the switches in the doors, the 6n has them in the dash, so at a minimum you'd need an ignition feed to the doors. It can be done but but may be a little challenging. It's Lways good to have a donor car in a scrappers as you could chop out as much loom as you can, if you got the connectors for the a pillar it would make it alot easier.
Ah, I see.
No it doesn't it's a 96 6n I got doors for notin and I want power windows
Ah, I see.
When you say connectors do you mean the bit on the posted that the door plugs in to ???
Sorry buddy, I didn't read your question properly,
If you wanted to find out if you have to wiring for electric windows , I would first check behind the cuddy hole under the heater controls. If there is 2 connectors there, then chances are that everything is there.
If its not there then you would probably need to make/ buy another loom for the switches to the fuse box and to the door.
Let me know buddy, as I could probably make a loom up for you if you'd like.
Edited by dixy
Yes, where the round rubber boot from the doors connects to.
If the got a pair from a 6n2 it would have the right pins then it would be a case of matching the colours you have on you cars loom and then just adding the extra wires for the switches etc.
Are you wanting to just add electric windows? Or are you wanting the 6n2 door cards as well ?
I ask because if you just wanted to fit the motors and have the switches in the dash this would be easier.
-also the 6n2 door card will not fit the 6n dash etc.
Using door cards the lot have 6n2 dash as wellcan sense it's gobs be a right ball ack to wire lol
^^^^^ that would be amazing buddy will let you know soon as I get chance to check ^^^^^^^
