Driver side window problem..
I have a mk4 and the windows in the car are windey up ones, although the driver side has broke. I think the glass has popped off the runners but I'm unsure how to fix it?
Cheers guys an gals
  • Views 572
Whip the doorcard off and have a look - that's the best bet so you can actually determine what has happened to it, as it could have fallen off the runners, cable snapped, mech broke etc etc! Until you take a look you don't know ;d
If it has fallen off the runners... it could be that the plastic clip and screw holding the metal clamp on the window has snapped off! Would be quite obvious as the window wouldnt be on the mechanism lol
If it's not that, could be mechanism or cable issues... If you have to, un-do the clamps holding in the window - remove the window and then un-do all of the 10mm bolts holding the window mechanism into place and remove it. This should let you see exactly what's going on!
Good luck :)
Edited by daveb142
