Polo gt gearbox mount needed
In need of a gear box mount for the polo gt AHD or any mounts that would fit possably 8p ?...
Needs to be the mount that has the the two bolts run horizontal not the mount with the three nuts on top like the 1.0 Gear box mount cheers
ps. needed urgently as my gearbox is on it's way out and don't think will last another week. The car is my daily so need for travelling to work hopefully can get one this week and fitt weekend thanks mike. 07539301657
  • Replies 9
  • Views 604
Bump
So any mk2/2f 5 speed mount then. I'll have a butchers, see if i have one spare. You swapped from a 4 speed box?
Edited by randombadger69
Side or rear mount?
Side or rear mount?
Will be a side mount. With two bolt holes going into captive nuts.
Erm yeah it's the one u see wen you look in the bay it secures the box to the inner bay directly under the coil pack. And yeah changing the 1.0 box for a gt box on my gt conversion
gonna pop up my unit in a bit, i'll see if i can find one for you.
I have a spare if you still in need?
You can have it if you pay the postage.
Hivpal your a life saver I've pmd you pal cheers
Now have the mount top man thanks alot
