Definitive mk2/3 rear disc conversion guide
Done already. These were the old set
  • 5 months later...
  • Replies 114
  • Views 48.4k
  • prankstar2003
    prankstar2003
    GT compensator is a bolt on fitment in the original place, but will require modification of the hardlines. I have a spare i may be persuaded to part with. PM me. The carriers question is a good one.
  • dubownerbilco
    dubownerbilco
    so i did some hunting today and picked up this lot: mk3 golf gti stub axels £30 mk2 golf gti rear brake carriers, although i asked for mk2 golf items, the ones he gave me have polo and passat w
  • dubownerbilco
    dubownerbilco
    i know which thread you are talking about and it is already in the faq, but as you said that only really cover's the cable issue, in this thread i am trying to cover the whole conversion process and w
I'm struggling to find a guide for rebuilding mk2 golf gti rear calipers that i have for my rear disc conversion
any help would be much apreciated
I've sourced the kit to do so just want pointing in the right direction for do's and dont's
thanks.
Just seen this. How did you get on? Rebuilding really is a piece of piss.
i had alot of travel when i first did my conversion turned out that alloy calipers dont like the bleed nipple being cracked alot and one was weeping
a friend of mine has a full rear beam off a mk2 golf, with corrado g60 callipers and carriers on it. iff i take everything off this am i good to go on my mk2f ?
  • 1 year later...
What actually makes it so difficult to convert the master cylinder to servo may i ask?
....waits to get mauled...
Are we all using back plates from a mk2 golf on this setup? Do they fit ok?
So how much would this set up cost roughly ?
Probably been mention before but I can be bothered going through all messages.
So I've got a conversion from scrappy with all new parts for £40 but don't know about handbrake cable and brake pipes, what should I use? I've got polo 6n.
Alex
Does anyone know if mk3 golf vr6 stub axels would work? They seem to look the same in photos. Thanks.
probably too late now but yes they would be fine :)
  • 1 year later...
does anybody have a reg for a mk 2 golf that i can use to order the discs and wheel bearings
A Google image search should bring up something.
However you may find eBay to be cheaper, the likes of ECP and GSF seem to be very expensive when it comes to brake discs and charge per disc...
  • 8 months later...
Gentlemen i have a question regarding the Bias Valve!
My cars a GT converted CL, so no Bias valve, the only GT parts missing to make it complete are the Bias Valve and the Rear beam, i have a GT rear beam sat in the shed which has the full disc conversion already fitted, it just needs reconditioning, but i have no Bias valve here. I have already fitted a 22mm master cylinder.
Correct me if i'm wrong, but theres two options for the bias valve.
Option 1 - Fit a used original GT/G40 bias valve, probably the proper way to do it but these are getting thin on the ground and are 25 years old now!
Option 2 - Fit one of these:
http://www.ebay.co.uk/itm/MCR-Brake-bias-proportion-valve-hydraulic-screw-type-adjustment-/222099545892?hash=item33b62a1f24:g:pIgAAOSwiYFXIGMB
Mount that on the bulkhead in the single brake pipe to the rear, my favored solution but how do i adjust this correctly from scratch?
  • 1 year later...
I recently did a rear disc conversion on my car, using the following parts:
  • 6n2 GTI rear stub axles
  • 6n2 GTI rear calipers & anchor brackets
  • 6n2 GTI drive flanges/wheel bearings
  • 6n2 GTI rear discs/pads
  • 6n2 GTI rear caliper flexi hoses
  • Mk2f handbrake cables
  • Handbrake cable spacers as per Kiz's drawing in this thread
Few notes:
I went with 6n2 stuff as it eliminates having a tapered wheel bearing setup. A 6n2 uses a drive flange which comes with the bearing, and then you just torque up a large hub nut like on the front. This is less maintenance than tapered bearings & hopefully will offer more camber/toe stiffness as a setup.
With regards to the handbrake cable, I machined some spacers like Kiz's drawing in this thread, however they needed to be shorter (think was 10-15mm shorter), and had to flip the brackets around on the rear beam (so they eyelet the cable goes through is BEHIND the beam, not in front like standard).
The 6n2 caliper flexi hoses are a short flexi, then have a long shaped piece of hard pipe, I shortened and reshaped this to match up to the standard Mk2f flexi from the beam to the body. I will be getting some custom made flexi's I think as reshaping a pipe thats already been formed isnt ideal.
I have fitted a bias valve too, which IMO is definitely needed. When I first fitted the brakes, I set it about half way in its adjustment range, and it would still easily lock the rear before the front, which is not ideal. Although if you do some research you'll discover a lot of rear calipers of this era/fitment will have different piston size..its probably best to try and use the smallest piston size you can find, dependant on what size brakes you have upfront to maintain a good brake bias/distribution.
I spent a fair bit as bought the best quality bearings etc I could find, and bias valve, had calipers rebuilt etc. But it looks a lot better, less maintenance and added gains of better stiffness in the bearings/hub assembly.
Hope this helps!
