6n2 clock cluster problem
My 6n2 has devided to start playing tricks on me,
The problem is the airbag lights staying on, then the abs warning light flashes and buzzes, then the oil light warns out, then my rev counter drops out, I'm thinkin either an ecu problem or instrument cluster problem, the vag com is returning back a malfunctioning indication light, i think if it was ecu then the vag com wouldnt read?
Iv tried the fuses under the bonnet (but not the interior ones) iv checked clock and ecu connections, iv also reset the ecu but the problem persists, anyone had any experience with similar issues any kind of advice would help
  • Views 830
surley it is the airbag light? sometimes the connectors for the belt pretensioners can go up the wall, bringing the airbag light on, they are under the seats. i have an airbag light and a cluster if you need them.
How much u askon for a cluster? And also its not just the air bag light its all of it abs light oil liggt surely a loose airbag connection wouldnt cause that?
