advice needed on primered body parts
I have a front wing on my car that has been primered until I can source one that's the same colour, I was told to sand the wing down until the paint was dull and use zinc primer, was I right to do this? Also in peoples experience or opinion how long will the wing last just being primered, thanks in advance
Edited by deanwt
  • Views 994
Sounds like the right way of doing it. You should be flatting the primer before colour.
In my experience, If you put a decent coat of primer on you should be fine for years.
In not garunteeing anything though.
Cheers mate, might get it painted after xmas if one of the same colour don't come up. I put 3 coats of zinc primer on, wing had no rust or anything so hopefully it should be ok
primer absors mouisture potentially causing premature rusting.......
Get some colour on it.
What if I just wacked some matt black on it until I get it sprayed, woulkd that preserve it a bit better
I am a body man what "POLOMON" said is excatly right primer/filler absorbs mouisture which causes micro blisters when you paint the panel it will look brill till few weeks then wee bubbles will apper all over it these a call micro blisters when happens there very hard to get rid of you will have to rub the panel back to bare metal when this happens. and some cases will still come back all the time ending in you needing a new panel
So what will need to do is heat the panel to dry out all the mouisture then top coat it to protect it
Okie dokie, am going to take it to bodyshop to get done if I can't get a complete wing so will expalin to them that its been primered for a while. Would painting it matt black as a temporary top coat protect It? Only asking as I have some spare lying around
Edited by deanwt
Just as I said buddy and you will be grand the top coat will have to be gloss
Cheers for the help guys, guna see what paint I can get the weekend
Edited by deanwt
