Retrofitting cruise control to a 6N2?
Hi
Iv just signed up, bought a white 6N2 last week!
I'm just wondering if it's possible to retrofit cruise control to a 1.4 16v (75) 6N2? I found an incredibly detailed tutorial for a lupo TDI, so I'm wondering if it's possible on a 6N2, I guess one of the most important things is, is the throttle fly-by-wire or cable?
Thank for your help
Jamie
  • Replies 10
  • Views 7.6k
Anything is possible if you have the know how.
The Polo and Lupo are virtually the same car so I don't see why it wouldn't work!
That's what I was hoping for thank you.
My second question, are they fly by wire or normal cable? Mines a w reg 1.; 16v 75bhp, iv searched And all I find is conflicting stories, and it's too cold to go check lol
AFAIK it's a cable throttle. 6N's are and it's basically the same setup...
What's the best way to check? I'm on my own do any ideas haha!
I presume if it's cable that will be a show stopper
Thanks again
Your car should be a fly by wire (no cable throttle) IF its a 16v which it should be i believe...
If it is, you can retrofit cruise control the same way as a golf mk4, lupo etc etc...you just have to have it enabled via vag com.
Yeah it's definetlly a 16v, I'll check for tonight when I'm home. I will have to find out the pins on the ecu though won't I?
Thanks again mate
AHW 16v Lupo is cable throttle.
I can grab the cable and pull it to open the flap.
If yours is cable throttle I'd look into this
Waeco Magic Speed controller
Conrad part no.: 851329 - 89
http://www1.conrad-uk.com/scripts/wgate/zc...amp;navi=oben_1
If its cable- its an 8v....all 16v mk5 polo's were fly by wire. Check the pedal box- if you see a green cable come off the acellerator pedal sensor or even notice the lack of a cable on the throttle then its fly by wire...
As for the ECU pins...i'm not certain which pins they would be- if you can list the equivelent pins from the lupo i can double check this hopefully. ;)
It's definetlly 16v, but I will check for the green cable when I go out! Thanks for your detailed reply, exactly what I needed thank you!
Here's the pins you requested
1. ECU 46 cruise on/off
2. ECU 45 Resume
3. ECU 44 Set
4. ECU 14 Enable cruise (& connect to ignition 12V for stalk)
Thanks in advance
Jamie
Edited by Jay_G
I'm afraid your wrong matey. It's cable :( ignition off, could hear the butterfly opening and closing with the pedal, and couldn't see a green cable (but it's hard to look with the cowling in place), definitely a 16v, got the 16v engine cover, insurance says it is.
