pedal rubber / corrado interior
first off is this the right pedal rubber for a mk2f coupe accelerator?
and how hard is it to fit a full corrado interior? obviously the more of the rado one fitted the better but i wouldn't mind too much if the doorcards were a no no
also anyone got pics of a rado one fitted?
Edited by VW+SWFC=:)
  • Replies 29
  • Views 2.2k
A lot of parts were interchangeable during that period weren't they?
front seats will be a straight swap, as will the steering wheel. But other than that i expect everything else will need custom fitting.
when i said full i meant the seats and doorcards really and I'm sure someone has fitted rado front and back seats before in a coupe
itl be doable if you put the effort in. think I've seen it on here done before
People have done it before but it's a shit of a job from what I've seen, have to cut the gram which the rear seat mounts onto from the corrado then weld it into the rear of the polo to get the seats to fit, I'm sure there a guide to it somewhere on here though...
Indeed there is a guide. You could remove the material and recover your current seats. Or remove the foam and reshape to fit the polo rear seat base?
Door cards at a no (polos are not even remotely the same shape as corrados!)
that pedal rubber fits i have one on mine , polos didnt have em from new
i thought it was mine that didn't have one as it was worn or something but obviously not! is an accelerator pedal rubber really that much of a luxury not worth fitting to a polo? :lol:
anyone got any more info on how the front seats fit? I'm rapidly becoming put off going the corrado seat route!
bro seriously, just get mk2 coupe s seats. or get golf gti seats and swap the golf frames for polo frames as i did
i already have a grey gt interior but i wanted something a bit nicer and I've heard people fit rado and scirocco ones, coupe s and golf seats would be worse than my current ones really
Front corrado seats will bolt straight in without any work. They sit much lower than normal ones.
Fitting the rears is proper hassle, I've just chucked a black seat cover over them :thumbsup:
oh right may aswell keep em then! nahh theyl be the same just nicer material/patterns
Scirocco ones are another option as the material is the same as genesis tartan so you could just use genesis rear seats
andthey sit super low... like a boss!!! lol
finally someone who actually knows not guessing :roll:
do they sit annoyingly low or just nicer low? i was looking at getting grey rado seats and keeping the rest of my current grey interior
anyone heard of anyone ever fitting the rear ones though?
i want grey seats really, to match the rest of the car
we all know that the fronts bolt straight in and sit low? none of us were guessing! corraddo and scirrocco seats sit lower, golf seats sit higher, rears will be a pig to fit unless you either bodge it, swap the seat frames or weld the right mounts ect in
i'd be up for swaping the frames and trimming off bits here and there but i wont have any mounts to weld on unless someone has a corrado shell they are scrapping willing to chop bits of their car
compared to the normal polo seats how low are they? i dont want the driving position to be all wrong
just a bit lower really, the drivers one should be height adjustable anyway so you can just have it how you want, personally if you already have gt seats in the colour you want id just stick with them unless there nackered!
they have a few holes here and there and the drivers right foam bucket bolster thing is worn and the foam gets ground out and falls onto the carpet, they look o.k but thats the problem, i'd like nicer seats really
fair play, if the rears are in alright condition surely you could just get some grey scirrocco/corrado fronts then?
the rear seats are o.k. yeah but i'd obviously rather have matching seat patterns
these are the seats in question, they look sooooo nice, not sure on the price though
yeah man there nice!!! pricey though!!!
Mega scene tax, they're not even leather?! I'd look into scirocco gt2 seats and a genesis rear bench tbh. As even if you did fit the fronts, can't see you making much money back if you decided to sell the rado rear bench.
they were just examples by the way but the same guy is selling his balck heated leather ones for £500 :shock:
but yeah there are others, like these which are cheaper but look in worse condition, I'm still at the research stage at the moment hence all the questions, i get paid in two weeks :)
