pedal rubber / corrado interior
like someone said, they are height adjustable so you can find a position you like. Mine also have a wheel half way up the seat so you can recline or bring forward the top half of the seat. Can get it to fit your back perfect with enough fiddling. Best replacement seats if you ask me.
A bloke on here did get rears to fit but it took ALOT of welding and cutting, might be able to find the thread if you do a search.
  • Replies 29
  • Views 2.2k
that pedal rubber fits i have one on mine , polos didnt have em from new
i thought it was mine that didn't have one as it was worn or something but obviously not! is an accelerator pedal rubber really that much of a luxury not worth fitting to a polo? :lol:
was only a very select few cars that got the rubber as standard , mk2 golfs never had em either
they do tidy it up a bit...vw still em too
what car did they come standard on then? mk3 golf? and i have now realised how the rear sits fit after doing a search, you need the metal rail that goes at the front of the seat for it to sit onto and without it they wont actually fit properly so i may just get a cheap pair of front seats
just a certain variant of the mk3 i think ...pretty rare as standard
rado seats are the best upgrade i have ever made to my GT! the fronts are brilliant being a bit lower and so much more comfy.
The rears do fit however for the backs its a case of lining them up right and drilling new bolt holes to mount them in the middle and the top mounts at the sides will need either a bolt installing to go into the standard polo catch or install a bolt or something similar into the car to go into the rado seats.
For the bases you can as someone stated put part of the rado into your car OR do it the easy way and just cut down the foam and cut and re weld the wirey frame the arm rest is a little annoying as it is slightly too long and overhangs the seat so i have cut mine down and bolted it in. i was left with a small gap around the seats so i have carpeted that and mounted a roll cage to make it look like the gap is meant to be there! Hope this helps!
