bucket seats in 6n
hi people, I'm in need of a bit of help, I got my 6n a few months ago and it came with two rage reclining bucket seat with polo frames bolted on them.
i test drove the car with these in and although the seats were very conformable they were far to high. so i asked to have OEM's in and he threw the seats in with the car
so my question is, is there a way i can lower the seat and still have the slide function?
TBA i just want the seats in because the OEM,s sponge is not that clever and digging in!!
  • Replies 11
  • Views 2.8k
Depends how theyve been put together, post up some pictures and someone might be able to help you
ud probs have to cut and weld them badboys tbh
so if i wanted to just put the seat in one place how would i attach it to the floor?
is the bar that its welded to to flat bar?? if it is, looks like thats as low you can go, unless you make custom sub frames yourself
:-S ok next qestion is there any one on here who can make subframes and how much? and is it possable to bolt straight to the floor in one perstion, is how?
i know someone who can make subframes and his from hucknall in notts so not too far from you mate
some higher spec 6n2's have height adjustment.
great do u have his contact number plz, PM me plz. cheers
i had height adjustable standard seats in my 6n but when i put buckets in they was too high even on the highest settin so i cut the frames down drilled some new holes an bobs you uncle
u wouldnt happen to have any photos at all for what u did, or may u could use my photo and draw on the frames so i can see what u did? cheer
