6N power steering pump questions
Hi,
Does anyone know which line is the send and which line is the return? I take it the send line is the one coming from the pump, to the rack via the reservoir?
Does anyone have a rough idea what pressure the pump runs at?
  • Views 577
Bump
From memory and without looking, I am pretty sure that the pipe with the 'dog-leg' in it is the flow pipe from the pump, but surely this can't be via the reservoir, or you would end up circulating hydraulic fluid from the pump to the reservoir, without any pressure to the ram?
Sorry, but I don't know what the working pressure or the stall pressure should be.
regards.
